Water and my HZJ 78
Water and my HZJ 78
Arrgggh!!!
Hi all,
Noticed at lunch today, that for some reason, the rubber foot mats in my HZJ were very wet underneath...
Upon closer inspection, I discovered that the floor was also wet....You could see water coming out around where the foot rest is on the drivers side...
After taking out a bit of the floor covering on the drivers side I discovered that EVERYTHING was VERY WET. The water unfortunately had nowhere to go, as holes were plugged with grommets. Have removed them now, so at least it can dry out a little bit....
Its off to the dealer ASAP....
Soggy Greetings
Andrew
Hi all,
Soggy Greetings
Andrew
The early bird catches the worm ... but the second mouse gets the cheese!
- netzmeister
- Administrator
Water and my HZJ 78
Hi Andrew!
Did you check the cable holes? Maybe the water came from the ventilation and got through them.
And: If you´re off to the dealer - don´t forget your wellington boots...
Der Netzmeister
Der Netzmeister
Water and my HZJ 78
Hi Andrew, I am sad to hear that you too do own an 'Aquarium'.
Just wanted to add: you may want to remove all floormats as the back tends to keep water for a very long time in summer even..........
Water and my HZJ 78
Hi Peter!
Good news is its ONLY on the drivers side...
Will get it checked out ASAP - before the whole car
starts to smell......
Water and my HZJ 78
Hello Andrew,
I had exactly the same problem on the driverside of my HZJ78. We checked all the cable holes and everything and at the end i think it was the sealing of the windshield. I went to a second Toyota Dealer and the windshieldsealing was the first Idea of the specialist there. He put a sealing compound all around ( it's a pain in the a.. to remove the the unused compound!) undernaeth the original sealing and that was the solution of my Problem.
Wish you good luck
Hubertus
Wish you good luck
Hubertus
Water and my HZJ 78
Hi Herbertus
Pain to remove??? Did the 2nd dealer just smear everything full of the stuff and not bother to clean up?
I take it that it WAS a warranty repair....
Andrew
Andrew
Water and my HZJ 78
Hello Andrew,
yes it was a warranty repair but you misunderstood me because the dealer made a perfect job and I didn't had to clean anything.
With still dry regards have a nice day
Hubertus (... and please not Herbertus )
- netzmeister
- Administrator
Water and my HZJ 78
Why..."Herbertus" is not that bad too...
Water and my HZJ 78
Sorry... was late
Andrew
Andrew
